Limit of number of products in the cart?
cnoelker
Post by cnoelker » 16 Sep 2020, 11:01
a customer notified me that he was not able to put more than 200 products into the cart.
Is there some kind of limit?
Claudia
boettner
Re: Limit of number of products in the cart?
Post by boettner » 16 Sep 2020, 16:38
Hi Claudia,
the BasketLimits Plugin is responsible for these limits.
Best
Robert.
Post by aimeos » 16 Sep 2020, 20:30
What does happen if the customer reaches 200 products? Is the limit the product count or the number of lines in the basket?
There is no built-in limit in Aimeos and theoretically, you can store as many products as are fitting into the session (usually a medium blob with 2^24 bytes).
cnoelker
Post by cnoelker » 17 Sep 2020, 11:23
I tried it out, today, and was not able to reproduce it, either. No problem to put more than 200 articles into the cart.
