favorite icon
Dinver
favorite icon
Post by Dinver » 15 Nov 2020, 10:59
Hi, there is simple way set favorite/watch icon (on / off), how on ebay or aliexpress?
Re: favorite icon
Post by aimeos » 16 Nov 2020, 10:41
You can enable/disable them using this configuration:
https://aimeos.org/docs/2020.x/config/c ... ions/#list
Add new ones in your own version of this template:
https://github.com/aimeos/ai-client-htm ... andard.php
Dinver
Re: favorite icon
Post by Dinver » 16 Nov 2020, 13:08
aimeos wrote: 16 Nov 2020, 10:41 You can enable/disable them using this configuration:
I edited template. I'm interested in how to determine if a product is on the favorites list. For change icon in template.
Re: favorite icon
Post by aimeos » 18 Nov 2020, 08:05
You may use the JSON REST API to check if the product is in the customers favorite list:
https://aimeos.org/docs/latest/frontend ... relations/
Dinver
Re: favorite icon
Post by Dinver » 20 Nov 2020, 07:42
aimeos wrote: 18 Nov 2020, 08:05 You may use the JSON REST API to check if the product is in the customers favorite list:
How get customers favorite list, in template?
Re: favorite icon
Post by aimeos » 21 Nov 2020, 10:16
Use the jQuery example from the docs:
var url = response['links']['customer/relationships']['href']; // from customer response
var args = {include: "product"};
var params = {};
if(options.meta.prefix) { // returned from OPTIONS call
    params[options.meta.prefix] = args;
} else {
    params = args
$.ajax({
    url: url,
    method: "GET",
    dataType: "json",
    data: params
}).done( function( result ) {
    console.log( result.data );
This requires the customer to be logged in. Contrary, pinned products are session based without the need to log in.
Dinver
Re: favorite icon
Post by Dinver » 23 Nov 2020, 15:08
aimeos wrote: 21 Nov 2020, 10:16 Use the jQuery example from the docs:
var params = {};
} else {
    params = args
$.ajax({
    url: url,
    method: "GET",
    dataType: "json",
    data: params
const url = '/jsonapi/customer'
		const params = {
			related: 'relationships',
			include: 'product',
			filter: {
        '==': {'customer.lists.type': 'favorite'}
			fields: {
        'customer/lists': 'id'
		$.ajax({
				url: url,
				method: "GET",
				dataType: "json",
				data: params
Returned all item favorites and item watched. Filter not working. Is there any way to return the id array, whithout trash json data?
Re: favorite icon
Post by aimeos » 25 Nov 2020, 18:03
Yes, the endpoint doesn't support filtering but you can limit the returned fields using:
const url = '/jsonapi/customer';
const params = {
	include: 'product',
	fields: {
	        'customer/lists': 'customer.lists.refid,customer.lists.type'
$.ajax({
	url: url,
	method: "GET",
	dataType: "json",
	data: params
Dinver
Re: favorite icon
Post by Dinver » 26 Nov 2020, 11:12
aimeos wrote: 25 Nov 2020, 18:03 Yes, the endpoint doesn't support filtering but you can limit the returned fields using:
const params = {
	include: 'product',
	fields: {
$.ajax({
	url: url,
	method: "GET",
	dataType: "json",
	data: params
Thanks! Is it possible to exclude from the response "links"?
I create action add product to cart "jsonapi/basket?Id=default&related=product". In response come a lot of unnecessary data. How to leave only data/attributes?
Re: favorite icon
Post by aimeos » 27 Nov 2020, 13:20
No, the links section is required by the jsonapi.org standard which this API follows.
