Vendor report generate
traiyani75
Post by traiyani75 » 02 Apr 2021, 09:13
Hello.
We are using aimeos on mobile applications. We have prepared different sites for individual vendors.
Now, we want to prepare products sell report for individual vendors.
So, do we have feature or function to check similar counts for individual sites or vendors?
Thanks In Advance.
Re: Vendor report generate
Post by aimeos » 06 Apr 2021, 07:53
Aggregating data for reports is only available in the admin backend and the admin JSON API, not in the frontend JSON API for security reasons. You can check the dashboard code to see how the data is aggregated, e.g.:
- https://github.com/aimeos/ai-admin-jqad ... es.js#L165
- https://github.com/aimeos/ai-admin-jqad ... js#L48-L85
