Change return type of payment provider
Kappa.yahyya
Post by Kappa.yahyya » 18 Jun 2021, 07:57
Hi
Iam working on aimeos/laravel version (on php 7.4)
I’ve created an extension to handle our custom methods , and in this case working on custom payment method for Stripe paymentIntent.
My problem is on “process” function of the payment provider , I need to return a json value ( which is returned form stipe paymentIntent api(Secret_key) ) using Response() method of laravel.
But the process function has a return type of “…\Helper\Form\Iface” and I can not change it from anywhere .
I used ‘ print “”; and exit; ‘ for my solution but I know its not a good way.
I am wondering is there any function that i can use to return a json ( so I don’t need to change the return type ) ?
BTW just thinking maybe there is an extension done and not need to spend time for it .
PS : i've attached my code here : https://ibb.co/fq69NRB
Re: Change return type of payment provider
Post by aimeos » 22 Jun 2021, 07:29
Is the reason you want to return a JSON answer that you are using the JSON REST API for communication between the client and the server?
Kappa.yahyya
Post by Kappa.yahyya » 22 Jun 2021, 10:29
Yes, we use JSON REST API .
ps : because stripe Reactjs library needs a key (secret key) that returns from a request in Backend to stripe api , so i need to receive this key from process method in json method.
Post by aimeos » 28 Jun 2021, 12:52
The best way would be to add this as key/attribute pair to the form object:
https://github.com/aimeos/aimeos-core/b ... d.php#L171
The code in your process() method would be something like this:
$list = [
	'stripekey' => new \Aimeos\MW\Criteria\Attribute\Standard( [
		'code' => 'stripekey',
		'internalcode' => 'stripekey',
		'label' => 'Striple token',
		'type' => 'string',
		'internaltype' => 'string',
		'default' => '<stripe publisable key>'
return new \Aimeos\MShop\Common\Helper\Form\Standard( $url, 'POST', $list );
Then, it will be available in the "meta" section of the response:
https://github.com/aimeos/ai-client-jso ... #L135-L137
Kappa.yahyya
Post by Kappa.yahyya » 13 Jul 2021, 14:40
thanks for the solution , but look how deep the data goes . is there any better solution?
Post by aimeos » 15 Jul 2021, 09:08
No, because the structure is defined by the jsonapi.org standard.
