Get field values
vikram
Get field values
Post by vikram » 28 Aug 2015, 08:13
I have items after a search execution. I need to access it non-basic values like price, description ect. How to do that in the php code. Some thing like the follow is not working.
$price = $item->getRefItems( 'price', 'default', 'default' );
The following works fine:
$item->getCode();
Re: Get field values
Post by aimeos » 29 Aug 2015, 22:39
vikram wrote: I have items after a search execution. I need to access it non-basic values like price, description ect. How to do that in the php code. Some thing like the follow is not working.
It works if you tell searchItems() that you want to to fetch the price items at well:
$manager->searchItems( $criteria, array( 'price' ) );
