Typo3 BE error : Missing argument in getParsedData()
vikram
Post by vikram » 02 Sep 2015, 06:39
I have got the latest code from Github.. and I get this error when I try to create a new content element in Typo3 (ver 7.2.0) backend:
#1: PHP Warning: Missing argument 3 for
TYPO3\CMS\Core\Localization\LocalizationFactory::getParsedData(),
called in var/www/html/typo3cms/cb_720/typo3conf/ext/aimeos/Classes/Custom/Wizicon.php
on line 38 and defined in /var/www/soft_dump/typo3_src-.2.0/typo3/sysext/core/Classes/Localization/LocalizationFactory.php line 75
Re: Typo3 BE error : Missing argument in getParsedData()
Post by aimeos » 02 Sep 2015, 08:47
Thanks for the hint! There seems to be different default parameters from 6.2 to 7.4.
We've added the parameters required in 7.2 and it should work now. Can you please check?
vikram
Post by vikram » 02 Sep 2015, 09:42
Yes working good now :)
