Admin interface stuck?
Re: Admin interface stuck?
As I mentioned, fixing that error created a new error. I still only get the Loading... square. Not I get an error related to the actual HTML in the response.
See attached screenshot...
Uncaught SyntaxError: Unexpected token < admin:1
- Screen Shot 2015-11-02 at 7.24.36 PM.png (188.1 KiB) Viewed 5741 times
Something seems to be really messed up. Can you make a screenshot of the loaded URLs in the "Network" tab from the Chrome developer tools, please?swpierce wrote:Code: Select all
I attached a screenshot of the XHR requests. I can grab the other requests also if needed - 80 total.
Thanks again for helping me out!
- Screen Shot 2015-11-03 at 6.45.24 AM.png (139.45 KiB) Viewed 5738 times
There are a lot of XHR request that are not related to Aimeos. Did you've integrated it into another application? If yes, could you please make a setup of Laravel/Aimeos only first?swpierce wrote:I attached a screenshot of the XHR requests. I can grab the other requests also if needed - 80 total
The only Aimeos XHR request is "index.php/admin/do". If it returns the index page, then the wrong URL is fetched internally (either due to the web server or the Laravel application).
No. The only thing in that directory is Aimeos.
I installed Composer.
I installed Laravel.
I ran "laravel new storefront"
I created an empty database and modified .env accordingly.
I modified the composer.json with the Aimeos stuff required.
I ran composer update.
I modified app.php to include the provider.
I ran php artisan vendor:publish
I ran php artisan migrate
I ran php artisan aimeos:setup --option=setup/default/demo:1
I ran php artisan aimeos:cache
I modified composer.json to install Bestmomo\Scafold so as to have the app.blade.php etc.
I modified app.php to include the Bestmomo Scafold provider.
I modified the app.blade.php to include the required Aimeos stuff.
I modified my http virtual host configuration to make the public folder in the laravel project the root.
I opened storefront.dev/index.php/list - ran into csrf-related error.
I modified Kernel.php to move csrf-related stuff to routeMiddleware.
I tried storefront.dev/index.php/list again - no problem - store works great.
I opened storefront.dev/index.php/admin - doesn't work.
I made no other changes and installed no other packages.
Can you redo the whole stuff but leave out the Bestmomo stuff? You can create the app.blade.php according to the docs:swpierce wrote: I modified composer.json to install Bestmomo\Scafold so as to have the app.blade.php etc.
https://aimeos.org/docs/Laravel/Adapt_base_template
Sure. I'll give it a shot!
Reinstall without using Bestmomo Scafold seems to have done the trick. Thanks for all the help!
