form input name for comment
obayesshelton
Post by obayesshelton » 11 Feb 2016, 16:53
Very simple one but what is the input name for the comment field in the order, I won't user to be able to input something on the checkout
Oli
Re: form input name for comment
Post by aimeos » 11 Feb 2016, 17:03
obayesshelton wrote: Very simple one but what is the input name for the comment field in the order, I won't user to be able to input something on the checkout
Currently, there's none in the checkout. We will add this possibility later and then it must be enabled explicitly.
obayesshelton
Post by obayesshelton » 11 Feb 2016, 17:09
Is there any way to add something to the order similar to how you do with the delivery by creating a MShop_Service_Provider_Decorator ?
Post by aimeos » 11 Feb 2016, 17:10
What do you exactly need?
obayesshelton
Post by obayesshelton » 11 Feb 2016, 17:37
Hey,
I just need to put an account number for an external service inside the users order.
I was going to use company name but I noticed that is not storing, is there an issue with that?
Oli
Post by aimeos » 11 Feb 2016, 20:55
obayesshelton wrote: I just need to put an account number for an external service inside the users order.
You should not reuse existing fields for different things, especially as adding custom fields is pretty simple.
Create a service provider decorator where you can define the required fields:
https://aimeos.org/docs/Developers/Libr ... figuration
Afterwards, add it to your delivery service provider entry and the fields will be automatically added to the delivery option where the customer can enter their additional data: https://aimeos.org/docs/User_Manual/Adm ... tors#Usage
The data is stored as an order base service attribute item in the database where you can work with it.
