Catalog Filter Problem
Metalics
Post by Metalics » 04 May 2016, 09:55
Assume that you have searched for "Column" via Catalog Filter Search. After searching, if you click any catalog link in the catalog filter tree, you receive Page Not Found error.
"Page Not Found
Reason: Segment "Column" was not a keyword for a postVarSet as expected on page with id=57."
(id=57, the id of the page on where Catalog List subpart added)
Re: Catalog Filter Problem
Post by aimeos » 04 May 2016, 10:17
Can you give us a bit more details about the context of the problem, maybe with a screenshot? Do you use own RealUrl rules?
