Error in Aimeos-Admin-Interface afer update to 16.7.0
franzrudolf
Post by franzrudolf » 31 Jul 2016, 17:07
Hi again,
if I choose the simple view -> product in the aimeos-admin-interface following error is thrown:
Again: Thanks a lot in advance for any help.
Re: Error in Aimeos-Admin-Interface afer update to 16.7.0
Post by aimeos » 01 Aug 2016, 14:41
The page decorator has been split up. Maybe your TYPO3 installation has some cached files. Maybe deleting ./typotemp/Cache/ helps
franzrudolf
Post by franzrudolf » 01 Aug 2016, 18:48
I deleted all files in the typo3temp-directory, but the error remains the same. Might this be a bug?
Post by aimeos » 02 Aug 2016, 10:17
If it would be general bug, more people would have reported this issue.
If APCu is enabled, the old configuration will remain in the memory of the web server until it's cleared. But the APCu option in the Aimeos configuration of the Extension manager isn't usually enabled.
franzrudolf
Post by franzrudolf » 02 Aug 2016, 14:18
That was it!! Obviously, the APC-Cache is set by default in the Extension-manager. Since I disabled it, there is no error in the admin-interface anymore.
Thank you so much. :mrgreen: :mrgreen: :mrgreen:
