Invalid locale ""
Metalics
Invalid locale ""
Post by Metalics » 28 Feb 2017, 19:24
It is impossible to start aimeos module in Typo3 backend after updating to Typo3 7.6.16.
It displays "Uncaught TYPO3 Exception" when you attempt to switch Expert mode.
Error Log:
Core: Exception handler (WEB): Uncaught TYPO3 Exception: Invalid locale "" | Aimeos\MW\Translation\Exception thrown in file /-----/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mwlib/src/MW/Translation/Base.php in line 34. Requested URL: http://www.elementel.com/typo3/index.ph ... 5Blang%5D=
I am not familiar with php errors. Maybe you can help.
Re: Invalid locale ""
Post by aimeos » 28 Feb 2017, 21:54
None of the admin interfaces work any more due to this change in TYPO3 7.6.16:
2017-02-16  4a92123  #79835          [BUGFIX] UriBuilder: Do not skip empty parameters (Markus Klein)
You can install this package which contains a workaround for the TYPO3 change:
https://aimeos.org/fileadmin/download/a ... 0-pre5.zip
Metalics
Post by Metalics » 28 Feb 2017, 22:21
Thank you. Working.
velo
Post by velo » 01 Mar 2017, 14:15
when will the fix be available for 16.10.x?
Thanks for helping.
Post by aimeos » 02 Mar 2017, 14:45
The workaround is already in the 2016.10 branch and if you use composer, available when using
"aimeos/aimeos-typo3": "2016.10.x-dev"
We plan a minor 16.10.4 release in TER beginning of next week.
