Questions around the TYPO3 integration and plugins as well as Flow and NeosCMS
Forum rules: Always add your TYPO3/Flow, Aimeos and PHP version as well as your environment (Linux/Mac/Win)
#2817 by Bollerx
26 May 2016, 11:53
i received the following error message while i executed the import and trying to execute the other scheduled tasks for aimeos shop(error on product site map task):
Execution of task "Aimeos Shop scheduler (aimeos)" failed with the following message: Not allowed to access "controller/jobs/product/export/sitemap/standard/template-header" configuration
i can't see the products, any idea?
(i'm using typo3 7.6.9 with Aimeos 16.4.3)
#2819 by Bollerx
26 May 2016, 13:24
i managed to fix the import , i can see the products now , it still shows me this error on Product site map while run the relative task job:
Executed: Aimeos Shop scheduler (aimeos)
i just reminder that if somebody has the same problem, i needed to create manually a product with "default" code, and after that the import task job, strange but true...
