Configure the checkout process
velo
Post by velo » 21 Jul 2016, 16:44
Is there any substitution for the following config?
https://aimeos.org/docs/Configuration/C ... t/subparts
I want to get rid of the delivery step like this:
plugin.tx_aimeos.settings.client.html.checkout.standard.default.subparts {
	0 = address
	1 = payment
	2 = summary
	3 = order
	4 = process
Thanks in advance
[pb]
velo
Re: Configure the checkout process
Post by velo » 21 Jul 2016, 18:11
So, I answer myself. :)
the correct Configuration is
client/html/checkout/standard/standard/subparts
Thanks anyway.
I will make a link in the above mentioned Documentation entry to this config.
Greetings [pb]
maco01
Post by maco01 » 16 May 2022, 11:09
SORRY - My mistake - it works now!
Thanks!
