language form-add new field
khizar
Re: language form-add new field
Post by khizar » 26 Jan 2021, 09:25
aimeos wrote: 26 Jan 2021, 09:00 You've done all necessary steps and I can't see anything missing. There's just an error somewhere. Did you check what's happening in the fromArray() methods for which I've added the links?
i put the "test entry" manually in database field and added a die and dump at the end of my toArray method inside
Standard.php(Locale/Item/Language)
public function toArray( bool $private = false ) : array
		$list = parent::toArray( $private );
		$list['locale.language.code'] = $this->getCode();
		$list['locale.language.label'] = $this->getLabel();
		$list['locale.language.status'] = $this->getStatus();
		dd($list);
		return $list;
so it gave me
following
	array:9 [▼
  "locale.language.id" => "zu"
  "locale.language.siteid" => ""
  "locale.language.ctime" => "2020-12-21 06:48:54"
  "locale.language.mtime" => "2021-01-25 06:52:53"
  "locale.language.editor" => "info@zsoft.com.pk"
  "test" => "test entry"
  "locale.language.code" => "zu"
  "locale.language.label" => "Zulusdfdfsdsadsd"
  "locale.language.status" => 0
so i replaced
value="<?= $enc->attr( $this->get( 'itemData/locale.language.test' ) ); ?>"
with
value="<?= $enc->attr( $this->get( 'itemData/test' ) ); ?>"
in template file through which i am able to display value in my new field but now when i hit save button it gives me error
because of "test" which should be locale.language.test
i also added dd in my from array at the end
$item = parent::fromArray( $list, $private );
		foreach( $list as $key => $value )
			switch( $key )
				case 'locale.language.code': $item = $item->setCode( $value ); break;
				case 'locale.language.label': $item = $item->setLabel( $value ); break;
				case 'locale.language.status': $item = $item->setStatus( (int) $value ); break;
				default: continue 2;
			unset( $list[$key] );
		dd($item);
		return $item;
which gives me
Aimeos\MShop\Locale\Item\Language\Standard {#1556 ▼
  -prefix: "locale.language."
  -available: true
  -modified: true
  #bdata: array:8 [▼
    "locale.language.label" => "Zulusdfdfsdsadsddfdf"
    "locale.language.status" => "0"
Post by aimeos » 26 Jan 2021, 09:38
Rename "locale.language.test" to "test" everywhere, then it will work
khizar
Post by khizar » 26 Jan 2021, 10:27
aimeos wrote: 26 Jan 2021, 09:38 Rename "locale.language.test" to "test" everywhere, then it will work
thankyou for your response i have done that step and value was stored.thankyou so much again.
actually i have another task and i have given a task to
add a field city in site form for which i have done same steps which i have done for language form .
1) i overwrite my template file item-sites(this file is in ai-sites extension) and directory i have used is
ext\moudhah\admin\jqadm\templates\locale\site and after that i have added a line "ai-sites" in the depends array of
manifest file(in the root off my extension)
<?php
return array(
	'name' => 'moudhah',
	'depends' => array(
		'aimeos-core',
		'ai-admin-jqadm',
		'ai-admin-jsonadm',
		'ai-client-html',
		'ai-client-jsonapi',
		'ai-controller-jobs',
		'ai-controller-frontend',
		'ai-sites'
	'include' => array(
		'lib/custom/src',
		'client/html/src',
		'client/jsonapi/src',
		'controller/common/src',
		'controller/frontend/src',
		'controller/jobs/src',
		'admin/jsonadm/src',
		'admin/jqadm/src',
	'i18n' => array(
		'admin' => 'admin/i18n',
		'admin/jsonadm' => 'admin/jsonadm/i18n',
		'client' => 'client/i18n',
		'client/code' => 'client/i18n/code',
		'controller/common' => 'controller/common/i18n',
		'controller/frontend' => 'controller/frontend/i18n',
		'controller/jobs' => 'controller/jobs/i18n',
		'mshop' => 'lib/custom/i18n',
	'config' => array(
		'config',
	'custom' => array(
		'admin/jqadm' => array(
			'admin/jqadm/manifest.jsb2',
		'admin/jqadm/templates' => array(
			'admin/jqadm/templates',
		'admin/jsonadm/templates' => array(
			'admin/jsonadm/templates',
		'client/html/templates' => array(
			'client/html/templates',
		'client/jsonapi/templates' => array(
			'client/jsonapi/templates',
		'controller/jobs' => array(
		'controller/jobs/templates' => array(
			'controller/jobs/templates',
	'setup' => array(
		'lib/custom/setup',
so through that i added city field successfully
2) i added a decorator Myproject.php in
ext\moudhah\lib\custom\src\MShop\Locale\Manager\Site\Decorator
which contains
	<?php
namespace Aimeos\MShop\Locale\Manager\Site\Decorator;
 class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base implements \Aimeos\MShop\Common\Manager\Decorator\Iface
    private $attr = array(
        'city'=> array(
            'code'=>'city',
            'internalcode'=>'mlocsi."city"',
            'label'=>'Site city',
            'type'=> 'string', // integer, float, etc.
            'internaltype'=> \Aimeos\MW\DB\Statement\Base::PARAM_STR, // _INT, _FLOAT, etc.
     public function getSaveAttributes() : array
         return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
     public function getSearchAttributes( $sub = false ) :array
         return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
3) i made change in mshop/config file
<?php
return [
    'locale' => [
		'manager' => [
            'site' => [
				'decorators' => [
					'local' => ['Myproject']
			'language' => [
				'decorators' => [
now when i update a site it successfully updates the value of city
but when i add new value it gives error because when i add die and dump in toarray method
		$list['locale.site.code'] = $this->getCode();
		$list['locale.site.label'] = $this->getLabel();
		$list['locale.site.config'] = $this->getConfig();
		$list['locale.site.status'] = $this->getStatus();
		$list['locale.site.hasChildren'] = $this->hasChildren();
		if( $private === true )
			$list['locale.site.level'] = $this->getLevel();
			$list['locale.site.parentid'] = $this->getParentId();
		dd($list);
		return $list;
if gives me
array:12 [▼
  "locale.site.id" => "15"
  "locale.site.siteid" => "1.15."
  "locale.site.ctime" => "2021-01-16 02:43:28"
  "locale.site.mtime" => "2021-01-26 10:06:08"
  "locale.site.editor" => "info@zsoft.com.pk"
  "locale.site.code" => "nike"
  "locale.site.label" => "Nike"
  "locale.site.config" => []
  "locale.site.status" => 1
  "locale.site.hasChildren" => false
  "locale.site.level" => 1
  "locale.site.parentid" => "1"
it is not picking city field which is successfully added in table
but when i add die and dump
public function fromArray( array &$list, bool $private = false ) : \Aimeos\MShop\Common\Item\Iface
			switch( $key )
				case 'locale.site.code': $item = $item->setCode( $value ); break;
				case 'locale.site.label': $item = $item->setLabel( $value ); break;
				case 'locale.site.status': $item = $item->setStatus( (int) $value ); break;
				case 'locale.site.config': $item = $item->setConfig( (array) $value ); break;
		dd($item);
		return $item;
Aimeos\MShop\Locale\Item\Site\Sites {#1563 ▼
  -deletedItems: []
  -children: []
  -node: Aimeos\MW\Tree\Node\DBNestedSet {#1489 ▶}
  -prefix: "locale.site."
  -available: true
  -modified: true
  #bdata: array:10 [▼
    "locale.site.label" => "Nikedfdf"
    "city" => "los angeles"
  -children: []
city is there so it updates successfully but not showing in the form and unable to create new one
* one more thing i want to ask when i update a site and do not change default fields and change only field which i
have added it does not update the new field value it only updates when i made changes in default fields.what should i
do update a site when i dont change default field ,ony change custom added fields.note i am using decorator aproach
* second thing is i want to store new field(city) data in uppercase then where should i do
khizar
Post by khizar » 27 Jan 2021, 07:17
please have a look at my problem
khizar
Post by khizar » 27 Jan 2021, 10:30
i am waiting for your reply
khizar
Post by khizar » 28 Jan 2021, 09:04
waiting for reply
khizar
Post by khizar » 29 Jan 2021, 06:35
its been 3 days i posted a question and you guys did not post single reply
Post by aimeos » 29 Jan 2021, 09:34
khizar wrote: 26 Jan 2021, 10:27 its been 3 days i posted a question and you guys did not post single reply
First of all, there's no guarantee to get a reply to your question at all in the forum. That depends on somebody who has time and knows the answer. If you need immediate support, ask the Aimeos company for help (the Aimeos Open Source project doesn't belong to Norbert's Aimeos company despite of the name). They offer 1:1 support, esp. for their extensions like the ai-sites one you are using:
https://aimeos.com/aimeos-gmbh/contact
khizar wrote: 26 Jan 2021, 10:27 city is there so it updates successfully but not showing in the form and unable to create new one
Hard to say, your code looks correctly. You should add more debug statements to see where the problem might be.
khizar wrote: 26 Jan 2021, 10:27 * one more thing i want to ask when i update a site and do not change default fields and change only field which i
There was a patch yesterday that fixes that in aimeos/aimeos-core:2020.10.x-dev. You can get it by executing:
composer req aimeos/aimeos-core:2020.10.x-dev
khizar wrote: 26 Jan 2021, 10:27 * second thing is i want to store new field(city) data in uppercase then where should i do
In that case, you could add a save() method to your manager decorator which receives the item(s) to save. There you can get the value from the item, convert it to uppercase and set it again in the item. Then, call the save() method of the unterlying manager:
	public function save( $items, bool $fetch = true )
		$items = map( $items )->each( function( $item ) {
			$item->set( 'city', strtoupper( $item->get( 'city' ) ) );
		return $this->getManager()->save( $items, $fetch );
khizar
Post by khizar » 30 Jan 2021, 09:16
aimeos wrote: 29 Jan 2021, 09:34
Hi friend,
actually now i have tried another approach by making a file Myproject.php in directory
<?php
namespace Aimeos\MShop\Locale\Manager\Site;
class Myproject extends Standard
    private $searchConfig = array(
        'locale.site.city'=> array(
            'code'=>'locale.site.city',
            'label'=>'Product oldcode',
 public function getSearchAttributes( bool $withsub = true ) : array
        $list = parent::getSearchAttributes( $withsub );
        foreach( $this->searchConfig as $key => $fields ) {
            $list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $fields );
        return $list;
    protected function createItemBase( array $data = [] ) : \Aimeos\MShop\Locale\Item\Site\Iface
		return new \Aimeos\MShop\Locale\Item\Site\Myproject( $data );
after that i added another file Myproject.php in directory
ext\moudhah\lib\custom\src\MShop\Locale\Item\Site
<?php
namespace Aimeos\MShop\Locale\Item\Site;
    private $myvalues;
    public function __construct(array $values)
        parent::__construct($values);
        $this->myvalues = $values;
    public function getCity()
        if( isset( $this->myvalues['locale.site.city'] ) ) {
            return (string) $this->myvalues['locale.site.city'];
        return '';
    public function setCity( $city )
        if ((string) $city !== $this->getCity()) {
            // exit("<br />616");
            $this->myvalues['locale.site.city'] = (string) $city;
            $this->setModified();
        return $this;
        $unknown = [];
        foreach ($list as $key => $value) {
            switch ($key) {
                case 'locale.site.city':
                    $this->setCity($value);
                    break;
                default:
                    $unknown[$key] = $value;
        // exit("<br />617");
        return $unknown;
		if( $private === true ) {
            $list['locale.site.city'] = $this->getCity();
	    return $list;
and added following code in my config/mshop.file
<?php
return [
	'locale' => [
		'manager' => [
			'site' => [
				'name' => 'Myproject',
				'standard' => [
					'insert' => array(
						'ansi' => '
							INSERT INTO "mshop_locale_site" ( :names
								"siteid", "code", "label", "config", "status", "editor",
								"mtime", "ctime", "parentid", "level", "nleft", "nright"
							SELECT :values
								?, ?, ?, ?, ?, ?, ?, ?, 0, 0,
								COALESCE( MAX("nright"), 0 ) + 1, COALESCE( MAX("nright"), 0 ) + 2
							FROM "mshop_locale_site"
					'update' => array(
						'ansi' => '
							UPDATE "mshop_locale_site"
							SET :names
								"siteid" = ?, "code" = ?, "label" = ?, "config" = ?, "status" = ?, "editor" = ?, "mtime" = ?
							WHERE id = ?
					'search' => array(
						'ansi' => '
							SELECT :columns
								mlocsi."id" AS "locale.site.id", mlocsi."siteid" AS "locale.site.siteid",
								mlocsi."code" AS "locale.site.code", mlocsi."label" AS "locale.site.label",
								mlocsi."config" AS "locale.site.config", mlocsi."status" AS "locale.site.status",
								mlocsi."editor" AS "locale.site.editor", mlocsi."mtime" AS "locale.site.mtime",
								mlocsi."ctime" AS "locale.site.ctime",
								mlocsi."city" AS "locale.site.city"
							FROM "mshop_locale_site" AS mlocsi
							WHERE mlocsi."level" = 0 AND :cond
							ORDER BY :order
							OFFSET :start ROWS FETCH NEXT :size ROWS ONLY
						'mysql' => '
							SELECT :columns
							ORDER BY :order
							LIMIT :size OFFSET :start
					'count' => array(
						'ansi' => '
							SELECT COUNT(*) AS "count"
							FROM (
								SELECT mlocsi."id"
								WHERE :cond
								ORDER BY mlocsi."id"
								OFFSET 0 ROWS FETCH NEXT 10000 ROWS ONLY
							) AS list
						'mysql' => '
							FROM (
								SELECT mlocsi."id"
								WHERE :cond
								LIMIT 10000 OFFSET 0
							) AS list
					'newid' => array(
						'db2' => 'SELECT IDENTITY_VAL_LOCAL()',
						'mysql' => 'SELECT LAST_INSERT_ID()',
						'oracle' => 'SELECT mshop_locale_site_seq.CURRVAL FROM DUAL',
						'pgsql' => 'SELECT lastval()',
						'sqlite' => 'SELECT last_insert_rowid()',
						'sqlsrv' => 'SELECT @@IDENTITY',
						'sqlanywhere' => 'SELECT @@IDENTITY',
i have added the field city successfully and after adding those files i manually entered a value in city field of default site
now when i open site form the list of sites are not showing,you can see in the following picture
when i further investigated i found that there are two files in ai-sites extension
ext\ai-sites\lib\custom\src\MShop\Locale\Manager\Site\Sites.php extends \Aimeos\MShop\Locale\Manager\Site\Standard
ext\ai-sites\lib\custom\src\MShop\Locale\Item\Site\Sites.php extends \Aimeos\MShop\Locale\Item\Site\Standard
Sites.php file is responsible for showing list of sites but when i added my manager and item files in my own extension
which are also extending the standard files from aimeos core the files which are in the ai-sites extension do not work
and it does not show the sites list.
now i am totally stuck at that point please guide me what should i do
Post by aimeos » 30 Jan 2021, 10:31
Don't extend from the Standard locale site manager class if you are using the ai-sites extension:
Instead, extend from the "Sites" class of that extension:
class Myproject extends Sites
