Checkout process-update shipping cost
Re: Checkout process-update shipping cost
Here you can see there is no Costdecorator which i have made(mentioned above).Do i have to add that decorator in configuration if that so how can i do thataimeos wrote: 09 Mar 2021, 18:00 Click on the "+" symbol right of the "Provider" field to add your decorator to the service:
https://aimeos.org/docs/latest/manual/s ... ors/#usage
You have used the wrong decorator namespace because in your code its for HTML client decorators, not for service decorators. The correct code would be:
Then, your class should be listed in the service panel of the admin backend.
<?php
namespace \Aimeos\MShop\Service\Provider\Decorator;
class Costdecorator
extends \Aimeos\MShop\Service\Provider\Decorator\Base
implements \Aimeos\MShop\Service\Provider\Decorator\Iface
public function calcPrice(\Aimeos\MShop\Order\Item\Base\Iface $basket)
{ dd('ok');
// do something before
$price = $this->getProvider()->calcPrice($basket);
// do something after
return $price;
