Integrate SDK and send invoice after order is created
Re: Integrate SDK and send invoice after order is created
Post by aimeos » 28 Mar 2021, 07:27
Every minute is fine and you should use the name of the delivery option the customer should see as label/name of the entry. You can also have several delivery options with different names and codes but the same provider value.
fadeeva05
Post by fadeeva05 » 30 Mar 2021, 19:27
Ok, thanks a lot. I have another question, to be able to use QuickBook API, I need to connect my website to the account on QuickBook, where and how I can create a page on admil panel to place my "Connect" button? I need controller to generate connect URL and pass it to view and then when user connected I need to save tokens in DB. What is the most appropriate way to do this?
Post by aimeos » 02 Apr 2021, 17:14
You mean an OAuth handshake? You can overwrite the template for the service detail panel and add the button there:
https://aimeos.org/docs/latest/admin/jq ... templates/
fadeeva05
Post by fadeeva05 » 02 Apr 2021, 18:03
Yes, I mean OAuth authorization. How I can add a backend code? I need to generate Authorization URL using QuickBook SDK and pass it to the template for the service detail panel. After the user goes through the authorization flow I get a response from quickbook with tokens which I need to process and save to db.
Post by aimeos » 06 Apr 2021, 15:00
The best way might be to create a subpart for the service panel where you can do all stuff you need:
https://aimeos.org/docs/latest/admin/jq ... -subparts/
