Statistik missing old Orders
rvhelp2
Re: Statistik missing old Orders
Post by rvhelp2 » 14 Jun 2023, 15:20
Thanks, but where in Typo3 can I adjust the log level? In the localconfiguration or in the typoscript base?
I have in the Typoscript:
madmin.log.manager.loglevel = 7 and config.madmin.log.manager.loglevel = 7
tested
Post by aimeos » 16 Jun 2023, 07:53
Backend configuration is explained here:
https://aimeos.org/docs/latest/typo3/cu ... in-backend
But TypoScript isn't the best option to configure backend settings because you never really know if it's actually applied or not. Add the configuration to the appropriate PHP config file instead:
