Aimeos Create an new extension and Api in it.
Re: Aimeos Create an new extension and Api in it.
No, that must be part of your Laravel application
- TEJASPARMAR
I just want to create a new page within an extension and load it on some URL/route.
How can we do that in an extension?
Only in the Laravel application itself, not in an Aimeos extension.
- TEJASPARMAR
Can we modify/override the checkout page within an extension on the same URL, but the content should be changed for the checkout page?
Yes, you can adapt the existing Aimeos pages without problem, e.g. for the checkout page have a look here:
https://aimeos.org/docs/latest/frontend ... omponents/
- TEJASPARMAR
Can we get products from the basket using code within an extension?
Also, can we add the javascript in an extension?
If yes, where can we add javascript?
Sure. Do you need the basket in the frontend, backend or in a job controller?TEJASPARMAR wrote: 25 Jun 2024, 13:17 Can we get products from the basket using code within an extension?
Yes. The easiest way is to create a Laravel theme extension where you can customize the CSS/JS completely.TEJASPARMAR wrote: 25 Jun 2024, 13:17 Also, can we add the javascript in an extension?
If you only want to add a few lines of JS to the used theme, add a file to the ./themes/client/html/ directory of your extension. Then, add that file path in the component where you need it by overwriting the header.php file of that component in your own extension. Here you can see how CSS/JS files are inclued:
https://github.com/aimeos/ai-client-htm ... er.php#L83
For your own file, e.g. in ./themes/client/html/custom.js use:
<script defer src="<?= $enc->attr( $this->content( 'custom.js', 'fs-theme', true ) ) ?>"></script>
- TEJASPARMAR
I have added javascript within an extension. But it is taking path of "public" folder in the web page.
Is there anyway to deploy our extension in the public/vendor or any way to change javascript path to our extension ?
If you copy the existing theme into a new directory besides, you can create a new theme that will be published to ./public/vendor/shop/themes/
- TEJASPARMAR
Refused to execute inline event handler because it violates the following Content Security Policy directive: "default-src 'self' 'nonce-/nqamicZj8GcbZ9UY9FyUQ=='". Either the 'unsafe-inline' keyword, a hash ('sha256-...'), or a nonce ('nonce-...') is required to enable inline execution. Note that hashes do not apply to event handlers, style attributes and javascript: navigations unless the 'unsafe-hashes' keyword is present. Note also that 'script-src' was not explicitly set, so 'default-src' is used as a fallback
Getting this error for security policy.
Can please help me for that ?
