Coupon codes issue
Re: Coupon codes issue
Post by aimeos » 17 Jan 2026, 10:27
Threre seems to be something wrong because 500 is "internal server error".
Do you have any helpful log entries?
matish
Post by matish » 17 Jan 2026, 12:48
aimeos wrote: 17 Jan 2026, 10:27 Threre seems to be something wrong because 500 is "internal server error".
Well, I posted a screenshot about it. It is on the bottom part.
Log says, that "The amount of coupon codes exceeds the allowed limit"
So if there is only 1 coupon allowed per cart, then it is logical. Only problem is that it is expressed as HTTP500 instead of HTTP409.
Also discovered another wierd issue with the coupons.
If the coupon is in cart, then I can not place the order, because the server says the product is out of stock.
If I remove the coupon, then order placement works.
Am I supposed to put the matching product to stock for the coupon to work?
It would be nice, that if it really is so, then adding the coupon itself should fail with some graceful error message.
Post by aimeos » 27 Mar 2026, 16:20
The problem will be fixed in the next release where plugins will return status 409 instead.
