CSV import
KarstenSoll
CSV import
Post by KarstenSoll » 04 Aug 2017, 11:02
Hello!
I'm trying to import articles from a CSV-file but it didn't work. Thats what I did:
1. I created a CSV like you did't in you example CSV
2. I added a new task in the scedular: Aimeos Shop Planer >> Task: Product import CSV. In the field TS-Configuration I wrote:
controller.jobs.product.import.csv.container.type = Zip
controller.jobs.product.import.csv.location = fileadmin/tmp/import.zip
3. I uploaded the ziped CSV file to "fileadmin/tmp/" an launch the task. - But it didn't work. No product was importet.
What is wrong?
Kind regards
Re: CSV import
Post by aimeos » 04 Aug 2017, 21:17
"fileadmin/tmp/import.zip" is probably wrong as the base path of the TYPO3 scheduler is probably the ./typo3/ directory. Try "../fileadmin/tmp/import.zip" or the absolute path instead.
