Index.php - routing
tkristis
Index.php - routing
Post by tkristis » 19 Oct 2017, 12:29
Hi, we're trying to set up aimeos on a staging environment on AWS with ec2.
We're using ubuntu 16.04, with the latest aimeos version, with PHP 7.0, and laravel 5.5.
We are having issues when it comes to routing, as the address seems to require index.php before it. If we try to link on any links, we for example from list to basket we get an 404 not found due to the lack of index.php.
We tried adding index.php as the landing page with apache, however when we do this we lose the css.
Anyone got any suggestions?
Thanks,
Kristis.
Re: Index.php - routing
Post by aimeos » 19 Oct 2017, 13:15
Make sure you've installed and activated mod_rewrite!
In your public folder is a .htaccess file, which rewrites the URLs. If mod_rewrite isn't available, you get the problems you describe.
tkristis
Post by tkristis » 19 Oct 2017, 13:37
Thank you for help!
