Selections: Products have all possible combinations
mattdev
Post by mattdev » 14 Nov 2017, 17:32
I noticed while I was testing the demo that depended the primary selector, I can only choose other selector options. I have an eCommerce site that will use all of the options with each of my selectors. Is there a way that I can implement this in the framework easily?
Re: Selections: Products have all possible combinations
Post by aimeos » 14 Nov 2017, 20:49
Do you mean all combinations of attribute, options, etc in selection products? That's already the case. You can combine all features you need.
mattdev
Post by mattdev » 14 Nov 2017, 21:10
Why does it not reflect this in the demo when I try to select different options with forcing me to choose only one when more than one is shown?
Post by aimeos » 14 Nov 2017, 21:16
If you refer to the selection product, not all combinations are added to the database or have stock. Therefore, only you can only select the available ones.
