Help with Json API - Filtering the product list
ntnsapre
Post by ntnsapre » 16 Jan 2018, 20:43
I've spent hours on this and I have a feeling I'm just doing it all wrong. How do I filter the list of products using the JSONAPI endpoint /jsonapi/product ? I specifically want to filter it by category and attributes.
Everything I try either returns ALL products, or returns name not valid. Here are a few things I've tried:
https://localhost/jsonapi/product?filter[=~][product.label]=mystring
https://localhost/jsonapi/product?filter[>][f_search]=mystring
https://localhost/jsonapi/product?filter[==][f_catid]=10
https://localhost/jsonapi/product?filter[==][product.f_attrid]=1
https://localhost/jsonapi/product?filter[==][attribute.code]=mystring
Aimeos version: 2017.10
PHP version: 7.1
Package: Laravel
Environment: Linux
Re: Help with Json API - Filtering the product list
Post by aimeos » 16 Jan 2018, 20:58
ntnsapre
Post by ntnsapre » 17 Jan 2018, 07:37
Thanks for the quick response, one issue though -
The filter by attribute url gives me an error:
"title": "Invalid operator \"f_attr\""
Post by aimeos » 17 Jan 2018, 09:45
Sorry, it must be: https://localhost/jsonapi/product?filter[f_attrid][]=1
In the text it was correct but in the example URL it was wrong. Has been fixed.
ntnsapre
Post by ntnsapre » 17 Jan 2018, 17:26
Thank you!
Anshul Dua
Post by Anshul Dua » 15 Mar 2018, 13:48
I created a attribute and add in a product characteristics and in options. But i am not able to search that particular product with that attribute id. If list the attribute is listing with product.
Can you tell me what is the reason?
Post by aimeos » 15 Mar 2018, 21:10
Can you post your code and a screenshot of your product attribute sub-panel in the admin interface?
Anshul Dua
Post by Anshul Dua » 16 Mar 2018, 06:17
I didn't do anything in the code. I am using Aimeos admin panel to add the attribute. I found one thing that when i added the attribute in the product characteristics. It doesn't reflect in mshop_index_attribute table. :|
Post by aimeos » 16 Mar 2018, 09:03
A screenshot of your product characteristic sub-panel for the product would be helpful. Did you add the product to a category so it gets indexed?
Anshul Dua
Post by Anshul Dua » 20 Mar 2018, 09:35
How can i filter using attribute and catalog id?
http://localhost/jsonapi/product?filter ... price,text
I am using this but did not get any success. It always filter only with attr_id
