Problem with $this->translate() function?
IevIef
Post by IevIef » 10 May 2018, 09:34
Hi
seems like for some unknown reason "Latest" are the one from the sort list which cannot be translated to russian (maybe to others too): "Упорядочить по: рейтингу Latest названию цене".
I see that it might be translated because it have the same as Relevance translation in ru.po file: msgid "Latest"
msgstr "последнему" and in \ext\ai-client-html\client\html\templat ... efault.php it has
$this->translate( 'client', 'Latest' )
but instead of $this->translate( 'client', 'Relevance' ) it does not translated and return result in English - Latest.
Help with advice please.
Re: Problem with $this->translate() function?
Post by aimeos » 11 May 2018, 05:40
According to Transifex, "Latest" isn't translated yet: https://www.transifex.com/aimeos/aimeos ... t%3Alatest
Maybe you can translate the missing strings?
IevIef
Post by IevIef » 12 May 2018, 17:32
Shure, I can translate to Ukrainian. How I see it was not translated yet. But I alredy translated this "Latest" and write it to the file but continuing return english variant instead of translated russian.. thats what I mean
Post by aimeos » 13 May 2018, 20:05
The easiest way is by using Transifex so we can integrate your translations into the next release.
Adding something to the .po file is only the step but you have to generate the MO file from it too:
https://aimeos.org/docs/Developers/Add_ ... anslations
IevIef
Post by IevIef » 16 May 2018, 15:44
Ok, I understand, thank you
