CSV Import works ok until I add stock fields.
johnnatan
Post by johnnatan » 01 Jun 2018, 00:20
Hi ameos TEAM !!
Congrats to all community !!
I'm new to this. I hope you can help me.
I put this in shop.php
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'location' => '/tmp/csv',
'container' => [
'type' => 'Directory',
'content' => 'CSV',
'item' => array(
1 => 'product.label', // UTF-8 encoded text, also used as product name
2 => 'product.type', // type of the product, e.g. "default" or "selection"
3 => 'product.status', // enabled (1) or disabled (0)
'text' => array(
6 => 'text.type', // e.g. "long" for long description
7 => 'text.content', // UTF-8 encoded text
'media' => array(
8 => 'media.url', // relative URL of the product image on the server
'price' => array(
9 => 'price.currencyid', // three letter ISO currency code
10 => 'price.quantity', // the quantity the price (for block pricing)
11 => 'price.value', // price with decimals separated by a dot
12 => 'price.taxrate', // tax rate with decimals separated by a dot
'attribute' => array(
13 => 'attribute.code', // code of an attribute, will be created if not exists
14 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
'product' => array(
15 => 'product.code', // e.g. EAN code of another product
16 => 'product.lists.type', // e.g. "suggestion" for suggested product
'property' => array(
17 => 'product.property.value', // arbitrary value for the corresponding type
18 => 'product.property.type', // e.g. "package-weight"
'catalog' => array(
19 => 'catalog.code', // e.g. Unique category code
20 => 'catalog.lists.type', // e.g. "promotion" for top seller products
'stock' => array(
21 => 'stock.stocklevel', // three letter ISO currency code
22 => 'stock.dateback', // three letter ISO currency code
Then I run this command
php artisan aimeos:jobs product/import/csv
"D40530","ARTICLE TEST","default",1,"short","ARTICLE TEST","long","ARTICLE_TEST","files/5/2/52ae69dfda6adbe87514776546ddc95f.jpg","USD",12,28.72,12.15,,,,"default",20.51,"package-weight","home","promotion",1000,"2000-01-01 00:00:00"
It loads the articule but stock info is missing. Any help ??
Thanks !!
just fresh installed aimeos and laravel running on php7.0
Re: CSV Import works ok until I add stock fields.
Post by aimeos » 01 Jun 2018, 21:03
You need to add a column for "stock.type" so the importer knows with type/warehouse your stock belongs to ("default" if you only have one).
johnnatan
Post by johnnatan » 03 Jun 2018, 21:10
aimeos wrote:You need to add a column for "stock.type" so the importer knows with type/warehouse your stock belongs to ("default" if you only have one).
Hi !!
thanks for your fast help !! sorry for delay
I'm still stuck. I add this field on shop.php file and csv but just imports product info and stock info stills missing
Also I manually edit each imported product and just save it in order to see it in listings.
this is the files and info that I'm using.
thanks again for your help and sucess to all the aimeos team !!!
Johnnatan
1.- shop.php file::
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'container' => [
'content' => 'CSV',
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'product' => array(
'catalog' => array(
'stock' => array(
21 => 'stock.stocklevel', // Integer
22 => 'stock.type', // the importer knows with type/warehouse your stock belongs to ("default" if you only have one).
23 => 'stock.dateback', // date intem available again
2.- csv file used
"job_csv_test","job csv test product","default",1,"short","short description","long","long description","path/to/image.jpg","USD",1,20,12,"import-test","size","","",18,"package-weight","home","promotion",22,"default","2018-07-01 00:00:00"
3.- command used
user@server:$ php artisan aimeos:jobs product/import/csv
Executing the Aimeos jobs for "default"
4.- MYSQL import log table (last row)
select * from madmin_log;
| 210 | 1 | message | 2018-06-03 20:58:38 | 3 | Not imported: Array
[21] => 22
[22] => default
[23] => 2018-07-01 00:00:00
| e68975b197b8e02eb5ddcee4b6e82a36 |
johnnatan
Re: CSV Import works ok until I add stock fields. [SOLVED]
Post by johnnatan » 04 Jun 2018, 06:36
I guys
I answer this question reading after read a little more. and after Mr aimeos user suggestions !!! Thanks a lot !!
I just added 'mapping'=> array( and closed. Finally Works !!
Thanks for your time and paticence..
Have all a Nice Day !!!
This is the file if someone needs it
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'container' => [
'content' => 'CSV',
'mapping'=> array(
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'product' => array(
'property' => array(I guys
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'container' => [
'content' => 'CSV',
'mapping'=> array(
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'product' => array(
'catalog' => array(
'stock' => array(
23 => 'stock.dateback', // three letter ISO currency code
CSV FILE USED
'catalog' => array(
'stock' => array(
CSV FILE USED
johnnatan
Re: CSV Import works ok until I add stock fields. [SOLVED][F
Post by johnnatan » 04 Jun 2018, 06:48
I guys
'controller' => [
'jobs' => [
'product' => [
'import' => [
'csv' => [
'container' => [
'content' => 'CSV',
'mapping'=> array(
'item' => array(
'text' => array(
'media' => array(
'price' => array(
'product' => array(
'catalog' => array(
'stock' => array(
23 => 'stock.dateback', // Returning date of item
CSV FILE USED
