User authentication failed due to invalid authentication val
woo13244
Post by woo13244 » 20 Aug 2018, 18:59
I am trying to use the Authroize.net Aim payment system. After entering my transaction key and login id i keep getting this error. "User authentication failed due to invalid authentication values." I have triple checked my key and login id. I have tried both the sandbox key and id with the authorizenet.testmode as yes and the live key with test mode off. I continue to get this error. Any tips on debugging this?
Re: User authentication failed due to invalid authentication
Post by aimeos » 23 Aug 2018, 18:34
Did you configured your payment service like described here?
https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
woo13244
Post by woo13244 » 24 Aug 2018, 16:58
yes i have created the 2 fields apiLoginId and transactionKey. for the default authorize.net.address, .authorize, and .testmode all to no. I am still getting the same error. Is there anywhere i can dump the api key so i can see if its for sure grabbing the key from the database? Thank you for the help! I recently dumped the $provider in Omnipay.php on line 877 and saw the only thing missing was the hashSecret. I am assuming this is the value i enter on the MD-5 Hash in the authorize.net settings. But even with or without the hash secret it still gives me the same error.
woo13244
Post by woo13244 » 27 Aug 2018, 13:56
I have solved the problem, i may have found a bit of an error in the docs. The authorizenet.testmode value was not actually changing the value. It would always come in as testmode = false, this is a problem since i must use the sandbox api to test before production. I have solved this by manually changing the default value manually in vendor/omnipay/authorizenet/src/AIMGateway.php line 29+30 to true. Thank you for the input and always responding you are awesome!
Post by aimeos » 28 Aug 2018, 10:53
Thanks for the hint!
You should then use only
testMode : 1
Documentation has been adapted.
