FixedRebate
Stefan80
FixedRebate
Post by Stefan80 » 11 Sep 2018, 09:25
what happens to a Coupon, if a code should be used twice or more.
For example: I have a 50€ Code , buy a product of 10€ ... is the code value now 40€ ?
thanks
Stefan80
Re: FixedRebate
Post by Stefan80 » 11 Sep 2018, 11:37
OK, its the Voucher-feature.
When was the Voucher addet to the Aimeos core?
Re: FixedRebate
Post by aimeos » 11 Sep 2018, 20:01
Starting with 2018.07 the voucher code incl. remaining values is available
Stefan80
Re: FixedRebate
Post by Stefan80 » 19 Sep 2018, 07:42
when I use "required.productcode (required)" and choose a non required product:
I get the basket error "Requirements for coupon code "rabattxyz" aren't met".
I want to translate/change this text - but in which file?
and: how can I use more than one product for "required.productcode" ?
thanks
Re: FixedRebate
Post by aimeos » 21 Sep 2018, 12:35
If none of the decorators fit, you can write one yourself:
https://github.com/aimeos/aimeos-core/t ... /Decorator
