Tax based on state
arcandoak
Tax based on state
Post by arcandoak » 21 Sep 2018, 01:06
aimeos: ~2018.07
Laravel: 5.6
I'm working on getting Aimeos' Laravel integration setup for my site. I only need to charge tax for orders that come from my state, so I'm hoping I don't need a complicated plugin.
I'm trying to make my own extension plugin that fires on "setAddress.after" and then i call this if it's not my state:
public function update( \Aimeos\MW\Observer\Publisher\Iface $basket, $event, $value = null )
$basket->getPrice()->setTaxRate('0.00');
Is there anything else I need to do change the tax rate, because it's not updating the tax in the basket/checkout summary?
Is setAddress.after the event I need to grab?
I've tried calling setTaxValue('0.00') as well and that didn't update the basket either.
Aimeos version: ~2018.10, PHP version: 7.2, Laravel version: 5.8
Re: Tax based on state
Post by aimeos » 21 Sep 2018, 12:47
You have to set the tax rates of the products to 0.00 and delete/add the products from/to the basket again. You also have to restore the tax rates if the customer changes the country again, so it gets a bit more complicated.
The Aimeos company is offering an extension that handles all the edge-cases:
https://aimeos.com/extensions/
arcandoak
Post by arcandoak » 21 Sep 2018, 15:02
aimeos wrote:You have to set the tax rates of the products to 0.00 and delete/add the products from/to the basket again. You also have to restore the tax rates if the customer changes the country again, so it gets a bit more complicated.
Thank you! I will give that a try. Is setAddress.after the correct event to use for this?
Post by aimeos » 24 Sep 2018, 13:55
Like said, it's a bit more difficult. You need to listen to at least addProduct.after, addService.after, for all the edge cases to a few more.
