Safest way to reset ORDER TABLE
sixbynine
Post by sixbynine » 22 Sep 2018, 07:13
I made some tests on Aimeos and I would like now to empty and reset the AI order tables ONLY (I would like to keep my users and products)!
Is there a command that allow that or do I need to manually clean it in the db?
Thank you very much,
sbn
Re: Safest way to reset ORDER TABLE
Post by aimeos » 24 Sep 2018, 13:57
You have to manually truncate the mshop_order* tables
sixbynine
Post by sixbynine » 24 Sep 2018, 17:27
That was my plan... but I wanted to be sure :)
Thank you very much !
