Multi-Shop Search not working
Manaf
Post by Manaf » 26 Nov 2018, 12:24
In Aimeos laravel, I created multi-shop using the command
./artisan aimeos:setup myshop2 default
./artisan aimeos:account --admin me@example.com myshop2
Then i added following lines in config/shop.php, the listing is working fine. but in search listing and search suggest dropdown not listing myshop2 products (only listing default site products) , i'm on stuck please help me with a solution. thanks a lot
'frontend' => array(
'mshop' => array(
'common' => array(
'manager' => array(
'sitecheck' => 0
Re: Multi-Shop Search not working
Post by aimeos » 27 Nov 2018, 17:06
Does it work if you execute
php artisan aimeos:jobs index/rebuild myshop2
Manaf
Post by Manaf » 28 Nov 2018, 01:22
Thanks the reply, i executed the command index/rebuilt, but myshop2 products are not showing in serach-list and suggest-list pages, i dig the code path: \vendor\aimeos\aimeos-core\lib\mwlib\src\MW\Criteria\Expression\Compare\SQL.php, assume only site_id =1 is including in the :cond, may be my mistake, can you please suggest me a solution.
