Overriding \Aimeos\MShop\Price\Item\Standard::setValue( )
EvE
Post by EvE » 23 Feb 2019, 13:18
I want to override \Aimeos\MShop\Price\Item\Standard::setValue( $price ), because I need more than 2 decimals for importing prices.
I'm using Aimeos 2018.10.* with Laravel 5.5.* on Linux with PHP 7.3.1 (Homestead).
I've added the following custom class:
/ext/myextension/lib/custom/src/MShop/Price/Item/MShopPriceItemStandardCustom.php
And registered it in shop.php with:
'mshop' => [
    'price' => [
        'item' => [
            'name' => 'MShopPriceItemStandardCustom'
This however does NOT work.
The same procedure however DOES work when I override the cache manager with:
/ext/myextension/lib/custom/src/MAdmin/Cache/Manager/MAdminCacheManagerRedisCustom.php
And registered it in shop.php:
'madmin' => [
    'cache' => [
        'manager' => [
            'name' => 'MAdminCacheManagerRedisCustom',
My questions are:
* Why does overriding \Aimeos\MShop\Price\Item\Standard does not work?
* Is there another way to achieve my goal to override \Aimeos\MShop\Price\Item\Standard::setValue( $price ) ?
Thanks in advance.
Re: Overriding \Aimeos\MShop\Price\Item\Standard::setValue(
Post by aimeos » 23 Feb 2019, 17:34
You can only configure alternative manager names, not item names. To use another item implementation, extend from the standard price manager, overwrite createItemBase() method and use your new item class there.
BTW: For which currency do you need more decimals? Bitcoin?
EvE
Post by EvE » 23 Feb 2019, 21:03
Thank you so much for your quick reply! This works.
The reason I need more decimals is because we have some very cheap products that can only be ordered in multiples of let's say 1000.
So the item price would be 0.008 (0.8 cents), but you can only order 1000, 2000, 5000, etc. of them.
