How to integrate aimeos with solr in laravel
SarvilAjwaliya
Post by SarvilAjwaliya » 20 Mar 2019, 12:31
i am using linux system.
Re: How to integrate aimeos with solr in laravel
Post by aimeos » 21 Mar 2019, 12:57
Depends how you want to integrate Solr - only for Aimeos or also for other data. For Aimeos, the best way is to replace or extend the index managers with your version that connects to Solr:
https://github.com/aimeos/aimeos-core/t ... ex/Manager
SarvilAjwaliya
Post by SarvilAjwaliya » 26 Mar 2019, 12:40
Thanks for your reply, but i need some more details on this.
Actually i am new to laravel and also for aimeos, so can you provide me more details on this or some steps by which i can achieve this.
Thanks in advance.
Post by aimeos » 28 Mar 2019, 15:52
That's a bit more complicated and it's nothing where a step by step guide exists. You should first get more conveniant with Aimeos and do this last.
BTW: If ElasticSearch would be also OK, the Aimeos company is offering a ready to install extension for that
