Angular 7 admin panel
Kent
Post by Kent » 18 Jun 2019, 17:57
Hi, Is it possible to build a Anguler 7 admin panel like this with Aimeos? https://keenthemes.com/metronic/
Re: Angular 7 admin panel
Post by aimeos » 19 Jun 2019, 08:18
Yes, no problem. The current dashboard is based on D3.js using the Aimeos Jsonadm API for retrieving the data for the graphs and you can do the sam with Angular.
Kent
Post by Kent » 19 Jun 2019, 08:33
Thanks will test that :)
