How to modify admin dashboard
lucadambros
Post by lucadambros » 24 Jun 2019, 14:51
Hi to everyone,
I'm new to Aimeos and I need help. I want to modify the admin dashboard by creating a new extension (so I can update Aimeos in the future).
I know that I have to use the extension generator but after that I don't know how to do the remaining part.
Is that possible? Can someone send me a step-by-step guide to solve my "problem"?
Thank you very much
Re: How to modify admin dashboard
Post by aimeos » 24 Jun 2019, 16:32
Create an Aimeos extension for your project and create your additionall theme CSS/JS files in the same directory structure as in the ai-admin-jqadm extension. Then, in your own extension, add your new files in the ./admin/jqadm/ manifest.jsb2 file and make sure, the ./manifest.php file contains:
'custom' => array(
	'admin/jqadm' => array(
		'admin/jqadm/manifest.jsb2',
lucadambros
Post by lucadambros » 25 Jun 2019, 06:31
Can you please explain how this can override the aimeos extension?
Can the extension also override the controller?
Edit: I solved the first problem but I still don't know how to extend controllers
Edit: Yes, the extension can override the controller laravel-package-f18/how-can-i-override- ... t2028.html
