Error SQLSTATE[3D000] Ai
thushim
Post by thushim » 27 Jun 2019, 09:02
Im new here.
I have installed the Aimoes web Shop distribution (Version 19.4.0) on Typo3 (9.5.7)(PHP Version 7.3.5)
When I click on the Aimeos Shop-Tab on the left side I get an error.
Typo 3 is installed on a local server (XAMPP)
Oops, an error occurred!
SQLSTATE[3D000]: Invalid catalog name: 1046 No database selected
Can someone help how I can get the problem solved????
Thanks in advance
Re: Error SQLSTATE[3D000] Ai
Post by aimeos » 27 Jun 2019, 09:24
Strange error! Does it only occur when you are using the Aimeos admin interface?
Which software and versions are you using? MySQL, Apache, etc.?
Does the Aimeos update script in the Extension Manager yield errors if you execute it?
Can you reproduce it if you do a clean installation again?
thushim
Post by thushim » 01 Jul 2019, 11:26
It only occures when I try to use the Aimoes shop tab.
Apache 2.4.39 MySQL 5.0.12
if i execute the update script it says:
Configuration parameter "database" missing in "db"
I already made a new installation but error is still there
Post by aimeos » 02 Jul 2019, 09:01
Are you sure you are using MySQL 5.0.12? This version is extremely old and unsupported.
The database name is used from your LocalConfiguration.php file, maybe the problem is there:
https://github.com/aimeos/aimeos-typo3/ ... rce.php#L9
thushim
Post by thushim » 02 Jul 2019, 10:32
Sorry my fault ist version 10.1.40
I have solved the problem, with a new clean installation, but now i get another error
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'orderportal.mshop_locale_site' doesn't exist
Post by aimeos » 02 Jul 2019, 10:49
Your tables haven't been created at all for some reason in that case. Please have a look at the end of the output of the update script to see what's the problem.
Version 10.1.40, is this MariaDB?
thushim
Post by thushim » 03 Jul 2019, 10:42
Problem solved
Changed charset to utf8 in the localconfig.php
