Payment and Delivery Status
- QuốcTrungNguyễnHoàng
I have problem with payment status and delivery status. It just show number of process. How can i config it show description of number status
And What happen when use choose "Create new account" option when checkout. I don't see any account create.
Re: Payment and Delivery Status
Seems like one of the Gettext files isn't readable or is missing on your server (in ./vendor/aimeos/aimeos-core/lib/mshoplib/i18n/).
The accounts are only created if you run the "customer/email/account" job controller via a cronjob.
So how can i fix it?
Language files: Remove the ./vendor/aimeos/aimeos-core directory on your server and run "composer update" again.
Accounts: Create a cronjob that runs "./artisan aimeos:jobs customer/email/account" regularly.
Here you can find the details for setting up job controllers for Laravel: https://aimeos.org/docs/Laravel/Configure_cronjobs
I removed and run composer update again but it not solve the problem
What Aimeos version are you using and what environment (Laravel)?
What language did you select? Maybe it's not translated for you language yet?
I'm use laravel 5.5, aimeos/aimeos-laravel 2018.10 and use VI (vietnamese) language
Most likely, that's not translated to Vietnamese yet. You can add translations here:
https://www.transifex.com/aimeos/public/
Simply register and start translating immediately.
We will integrate new and updated translations before we do new releases.
Thank you. But for now please tell me what payment and delivery status description with status code from -1 to 6 and 7
Please have a look here: https://github.com/aimeos/aimeos-core/b ... p#L44-L153
