Check orders
Amber
Check orders
Post by Amber » 10 Sep 2019, 02:51
How do customers log in to the list to check current orders or to search historical orders? (https://localhost/list)
Re: Check orders
Post by aimeos » 10 Sep 2019, 07:13
You are most likely use Laravel, don't you?
Set up authentication like desribed in the guide (required for both, admin and frontend login) and add a link to the "my-account" route in your app.blade.php template:
https://github.com/aimeos/aimeos-laravel#admin
