Upgrade error
kuoyehs
Upgrade error
Post by kuoyehs » 24 Sep 2019, 08:02
I upgrade "aimeos/aimeos-laravel" package 2018.10.4 to 2019.07.4, and "aimeos/aimeos-core", "aimeos/ai-client-html", "aimeos/aimeos-core" related package 2018.10.x-dev to 2019.07.x-dev.
I follow the document https://aimeos.org/docs/Laravel/Upgrade to upgrade, but when I use "php artisan aimeos:setup", and have the error message.
 SQLSTATE[42601]: Syntax error: 7 ERROR:  syntax error at or near ""unq_msindpr_p_s_prid_lt""
  LINE 1: ALTER TABLE "mshop_index_price" DROP INDEX "unq_msindpr_p_s_...
I use "php artisan aimeos:account sandy@visual-next.com --admin" to add admin account have the error message.
SQLSTATE[42703]: Undefined column: 7 ERROR:  column lvuli.type does not exist
  LINE 3: ...   lvuli."parentid" AS "customer.lists.parentid", lvuli."typ...
  HINT:  Perhaps you meant to reference the column "lvuli.typeid".
I use laravel 5.4, and postgreSQL.
Re: Upgrade error
Post by aimeos » 24 Sep 2019, 20:42
PostgreSQL doesn't support the "ALTER TABLE ... DROP INDEX ..." syntax.
Can you please use
"aimeos/aimeos-core": "2019.07.x-dev"
in your composer.json and run "composer update afterwards? When the latest version is installed, you can try again running "aimeos:setup".
kuoyehs
Re: Upgrade error
Post by kuoyehs » 25 Sep 2019, 03:59
My composer.json
After I run "composer update", I run "php artisan aimeos:setup", but have the error message.
SQLSTATE[42601]: Syntax error: 7 ERROR:  syntax error at or near ""idx_msindte_value""
  LINE 1: ALTER TABLE "mshop_index_text" DROP INDEX "idx_msindte_value...
Re: Upgrade error
Post by aimeos » 26 Sep 2019, 07:44
Can you make sure that you have commit b85bb89b9d73e035db9ac8b03e86b26f73311cd3 (run "composer show" to display the installed versions).
kuoyehs
Re: Upgrade error
Post by kuoyehs » 26 Sep 2019, 09:19
I run "composer show", these is version.
Re: Upgrade error
Post by aimeos » 26 Sep 2019, 19:31
We removed another setup task as well that contained non-PostgreSQL compatible statements. Can you please update and try again?
