How to use the Stripe hosted checkout page
Re: How to use the Stripe hosted checkout page
Post by aimeos » 07 Oct 2019, 15:55
Currently, the Omnipay driver seems to support Charge and Intend API only:
https://github.com/thephpleague/omnipay ... asic-usage
You could create a PR for the Omnipay Stripe driver that handles the checkout page API.
torresrecife
Post by torresrecife » 14 May 2020, 17:03
Hello mdv2, did you manage to do it the way you wanted? I need to do the same thing. Can you post as you did?
