Mollie renewed SSL certificate
Mollie has updated their SSL certificate and now Omnipay has to be updated with the new SSL certificate. See https://status.mollie.com/
When is this fixed?
When is this fixed?
Re: Mollie renewed SSL certificate
There are no changes in the Omnipay driver for Mollie required because:
This isn't the case AFAIK1. if you configured your custom API client to expect a specific certificate (which is discouraged) you will need to accommodate for this change.
This is done in the operating system2. If your API client connects from (very) outdated platforms you will need to verify that your system trusts the certificate issuer (USERTrust). Test the connection at https://test.mollie.com/
This is the error we get:
[curl] 60: SSL certificate problem: unable to get local issuer certificate [url] https://api.mollie.nl/v1/payments
Like said, make sure that you update the certificated in your operating system:
I've never done this before. This is the first time this happens. I don't know where and how to update it.
If you aren't hosting your web site yourself, you should ask your hoster because in that case you can't do it yourself.
I tested another webshop and that has no problems. It has something to do the with omnipay. It uses also an deprecated api v1 of Mollie.
The certificates are updated but it's still not working! What is going wrong? Which curl-command is used in which file to make the connection? Maybe we can extend with "-k" parameter.
I received an updated cacert.pem from Mollie and installed it but still get the same error message.
Can you explain how Aimeos connects to Mollie? Does it use a seperate certificate-file?
Aimeos uses Omnipay and the omnipay-mollie driver:
https://github.com/thephpleague/omnipay-mollie
For details about how the mollie driver works, please ask the Omnipay guys. I think it uses the guzzle-http package (http://docs.guzzlephp.org/en/stable/) and Guzzle uses the PHP methods to connect to the Mollie server which uses the OpenSSL libraries. Something like that.
