JSONADM API Relationship
matteovg7
Post by matteovg7 » 12 Dec 2019, 16:21
Hi, I can't figure out how to manage the relationships using JSONADM API.
For example, if I want to add a text to an existing catalog item, how can I achieve that?
I am able to add the text but I can't understand how to relate them to the catalog item.
Thank you.
Re: JSONADM API Relationship
Post by aimeos » 13 Dec 2019, 14:45
We use the Jsonadm API mainly for fetching data and updating things like stocks. Managing relations between domains isn't implemented yet but we are also interested in adding this to the API. If you can create a PR, we will help you to get this done and merge it for sure :-)
Post by aimeos » 13 Dec 2019, 14:53
The ai-client-jsonapi package contains an example how to manage releationships and properties:
https://github.com/aimeos/ai-client-jso ... i/Customer
matteovg7
Post by matteovg7 » 16 Dec 2019, 13:32
Ok, I studied the code and I saw that the saveRelationships method was already implemented, but the parameter "type" was missing in the $listItem array.
At the moment I solved the problem adding in my extension this line in this file at line 457: https://github.com/aimeos/ai-admin-json ... m/Base.php
$listItem->setType( "default" );
I know that isn't a definitive solution but I'm very new to Aimeos, I hope that in the next future I'm able to fix this in a definitive manner.
Post by aimeos » 16 Dec 2019, 14:07
That should do the job :-)
Can you please create a pull request for your change?
matteovg7
Post by matteovg7 » 16 Dec 2019, 15:10
Post by aimeos » 16 Dec 2019, 18:36
We've modified you PR a bit because you should still be able to pass the list type in a POST or PATCH request.
