Deleted
Re: Display sub-sub categories
Post by aimeos » 16 Dec 2019, 10:28
Not sure if I understand correctly but if you always want to display the first two levels of categories, you can use
https://aimeos.org/docs/Configuration/C ... els-always
rowild
Post by rowild » 09 Jun 2020, 11:44
May I ask, if this is still valid?
I changed my TYPO3-TS-setup to this:
plugin.tx_aimeos.settings {
    // CONTROLLER
    controller {
        frontend {
            catalog.levels-always = 2
but only the first category of the catalog is shown (it has not products, only those in the second level have products).
Do I have to change the template (lists/body-standard-php) somehow?
Post by aimeos » 13 Jun 2020, 14:26
That doesn't work because TYPO3 overwrites the setting with the flexform value from the plugin configuration even if it's empty.
