Stripe Payments not appearing as option in Services or on Checkout
I'm running Aimeos 2019.10 on Larvel 6.7 and have installed ai-payments and ominipay/stripe.
I'm developing on Windows 10 using XAMPP for Windows 7.2.24 (PHP 7.2)
Aimeos is running fine but Stripe does not appear as an option in the backend Services. Nor does it appear as an option on checkout.
(I've run composer update, php artisan config:clear and aimeos:cache
I've defined the stripe keys in .env. Are there additional steps required to get this fully implemented? Would be grateful if anyone can point me in the right direction.
Here's my composer.json file.
Here are the relevant components of my installation
"name": "aimeos/aimeos",
"description": "Aimeos shop system",
"keywords": ["Aimeos", "e-commerce", "shop", "laravel", "distribution"],
"license": "MIT",
"type": "project",
"prefer-stable": true,
"minimum-stability": "dev",
"repositories": [{
"type": "composer",
"url": "https://packages.aimeos.org/aimeoscom"
"require": {
"php": "^7.2",
"aimeos/ai-payments": "^2019.10",
"aimeos/aimeos-laravel": "~2019.10",
"fideloper/proxy": "^4.0",
"laravel/framework": "^6.0",
"laravel/tinker": "^1.0",
"laravel/ui": "^1.0",
"league/omnipay": "^3.0",
"omnipay/stripe": "^3.1"
"require-dev": {
"facade/ignition": "^1.4",
"fzaninotto/faker": "^1.4",
"mockery/mockery": "^1.0",
"nunomaduro/collision": "^3.0",
"phpunit/phpunit": "^8.0"
"config": {
"optimize-autoloader": true,
"preferred-install": "dist",
"sort-packages": true
"extra": {
"laravel": {
"dont-discover": []
"autoload": {
"psr-4": {
"App\\": "app/"
"classmap": [
"database/seeds",
"database/factories"
"autoload-dev": {
"psr-4": {
"Tests\\": "tests/"
"scripts": {
"post-autoload-dump": [
"Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
"@php artisan package:discover --ansi"
"@php -r \"file_exists('.env') || copy('.env.example', '.env');\"",
"@php -r \"mkdir('public/files'); mkdir('public/preview'); mkdir('public/uploads');\""
"post-create-project-cmd": [
"@php artisan key:generate --ansi",
"App\\Composer::configure",
"@php artisan migrate",
"App\\Composer::setup",
"App\\Composer::account"
"post-update-cmd": [
"@php artisan vendor:publish --tag=public --force"
}Here are the relevant components of my installation
aimeos/ai-admin-jqadm 2019.10.7 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm 2019.10.2 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2019.10.10 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2019.10.2 Aimeos JSON API extension
aimeos/ai-controller-frontend 2019.10.5 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2019.10.4 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2019.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2019.10.2 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments 2019.10.1 Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2019.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2019.10.9 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2019.10.1 Professional, full-featured and high performance Laravel e-commerce package for
laravel/framework v6.7.0 The Laravel Framework.
laravel/tinker v1.0.10 Powerful REPL for the Laravel framework.
laravel/ui v1.1.1 Laravel UI utilities and presets.
omnipay/common v3.0.2 Common components for Omnipay payment processing library
omnipay/stripe v3.1.0 Stripe driver for the Omnipay payment processing libraryRe: Stripe Payments not appearing as option in Services or on Checkout
Didn't realize that one has to create a new Stripe service record in the Services option in the back-end and populate the required stripe variables and keys.
Now it is appearing and payments re working in test mode.
