Rest API to check user attach to session or not
traiyani75
Post by traiyani75 » 22 Jan 2020, 04:53
How do I get to know that the user is attached with a session token or not via rest API call? Is there any way to do that?
Re: Rest API to check user attach to session or not
Post by aimeos » 23 Jan 2020, 10:11
You can use a GET request for the "customer" endpoint. If it returns an empty customer item, the user isn't logged in.
traiyani75
Post by traiyani75 » 25 Jan 2020, 11:35
Thanks for the help. It works.
Now, I want to get all the orders list which is placed by the user. How do I get all the orders data?
I have tried to use order endpoint, but it returns an only id. How do I get all the values of that order?
Post by aimeos » 26 Jan 2020, 16:54
That's still missing while relatively easy to implement:
1.) Use the order/base manager to retrieve the corresponding order/base items here: https://github.com/aimeos/ai-client-jso ... hp#L50-L55
// $items -> use getBaseId() to get order base ID
$manager = \Aimeos\MShop::create( $context, 'order/base' );
$search = $manager->createSearch()->setSlice( 0, count( $items ) );
$search->setConditions( $search->compare( '==', 'order.base.id', $baseIds ) );
$view->baseItems = $manager->searchItems( $search );
2.) Copy the functions from the basket template to the order template and merge the $entryFcn to with the existing one so it outputs the order and order/base data together:
- https://github.com/aimeos/ai-client-jso ... p#L31-L229
- https://github.com/aimeos/ai-client-jso ... andard.php
3.) Create a pull request at Github with your code :-)
