Get products count into cart
traiyani75
Post by traiyani75 » 11 Feb 2020, 11:14
Hello, we are using laravel apis to connect aimeos into mobile applications.
We need API to get products list count in cart. So we can show count over the cart icon.
Re: Get products count into cart
Post by aimeos » 12 Feb 2020, 13:08
Use the basket endpoint and count the products in the basket. Thus, you can also display a small basket immediately in the frontend when a user clicks on the icon. To minimize the transfered data, you can add
include=basket/product
to retrieve the products but not the address and service items and you can use
fields[basket]=order.base.price&fields[basket/product]=order.base.product.name,order.base.product.mediaurl,order.base.product.price
to limit the fields sent to the client
traiyani75
Post by traiyani75 » 15 Feb 2020, 07:38
I have tried this api, but it returning all data every time.
{base-url}/default/jsonapi/basket?include=basket/product
Post by aimeos » 16 Feb 2020, 09:19
Sorry, forgot the "include" parameter and there was a problem filtering related basket fields. Please run "composer update" and use an URL like that:
http://127.0.0.1:8000/jsonapi/basket?included=basket/product&fields[basket]=order.base.price&fields[basket/product]=order.base.product.name,order.base.product.mediaurl,order.base.product.price
traiyani75
Post by traiyani75 » 25 Feb 2020, 11:50
It only filters products from the basket, But still, it returns all data into products object
Post by aimeos » 26 Feb 2020, 08:44
Did you run "composer update"? Both, 2019.10.4 and dev-master only return the fields mentioned in the "fields[basket/product]" parameter:
aimeos/ai-client-jsonapi              2019.10.4             Aimeos JSON API extension
aimeos/ai-client-jsonapi              dev-master 6dd20da Aimeos JSON API extension
