install fails over and over
mikeyapina@gmail.com
Post by mikeyapina@gmail.com » 06 Mar 2020, 22:51
so the script goes through its steps with no errors.
I change the appropriate setting on the server and they are correct
but the public page shows nothing
http://ov3rt.com/public/
I put it that way so you can see everything is there .. the permissions are right u the tool does to work.
m.
SaurabhSharma
Re: install fails over and over
Post by SaurabhSharma » 07 Mar 2020, 04:34
It says your mysql db credentials are not correct. If they are try changing host from localhost to 127.0.0.1
Post by aimeos » 07 Mar 2020, 16:09
Your domain (http://ov3rt.com/) must point to the public folder of your installation. It's not allowed that "/public/" is a subfolder of your domain.
