Fetch product refItems with their stock levels
SaurabhSharma
Post by SaurabhSharma » 07 Mar 2020, 07:55
I can get list of variant products for a particular product by using
$item->getRefItems('product')
What I want is to get ref items along with their stock levels. Also I tried looping through refitems but there's no "stock" domain right?
So what method returns the stock data related to a product?
Re: Fetch product refItems with their stock levels
Post by aimeos » 08 Mar 2020, 10:35
There's no easy way yet to retrieve the stock items associated to the product items. getRefItems() won't help because these are only the items that are referenced by the mshop_product_list table.
There are already two methods that do something similar you need:
- getCatalogItems()
- getSupplierItems()
We've added a new method getStockItems() now and ported that back to 2019.10 too. If you execute
composer req aimeos/aimeos-core:2019.10.x-dev
you can use the new method afterwards:
$product->getStockItems()
