Get sites details from product id
traiyani75
Post by traiyani75 » 23 Apr 2020, 19:36
Hello, we are using laravel JSON API on the application side for android and ios.
Most of the things are done, but now we need to add the distributor name of the product.
So, we have added multiple sites into main parent, and every site we have added 10-10 products. Now, We need to show the product with the site's name. Like product-A is selling by Xyz.
How do we achieve this?
traiyani75
Re: Get sites details from product id
Post by traiyani75 » 28 Apr 2020, 14:06
hello, Is there any solution for that? We need to show products by vendor name as well?
For that, we need to show vendor name into product details first then from there the user can visit the complete vendor store.
Will it be possible?
Post by aimeos » 29 Apr 2020, 09:28
There's no way to retrieve all available sites using the JSON REST API for security reasons. If you need the site name, you have to extend the product endpoint class (https://github.com/aimeos/ai-client-jso ... #L281-L319), fetch the locale site items for the products returned (using $product->getSiteId() and the searchItems() method of the locale site manager) and add that information in the product template (https://github.com/aimeos/ai-client-jso ... #L106-L133)
Post by aimeos » 29 Sep 2023, 09:13
Site information is now available per product if you add "include=locale.site"
