Search products API
traiyani75
Search products API
Post by traiyani75 » 18 Aug 2020, 05:24
We have products with two language, arabic and english. We are using Rest APIs on mobile side. Now how do we search product from both the languages. Currently we are able to search english text when we pass locale=en and arabic text when we passed locale=ar. How do we make this search into both the language without checking locale parameter.
Thanks & Regards
Re: Search products API
Post by aimeos » 19 Aug 2020, 07:28
There's no way to search for all texts regardless of the language because usually it makes no sense.
But you can set the language of all English texts to "All" so they are also used if you pass "ar" as language.
traiyani75
Post by traiyani75 » 28 Aug 2020, 10:39
Yes, but we cant set all for both language, else on application side we will not able to detect text language. We need this filtering on both side either arabic or english.
