which is the fastest?
gebo
Post by gebo » 20 Oct 2020, 16:40
I intended to start e-commerce website but I need the fastest package .Is It slim or symphony or laravel or typo3 cms plugin? :roll:
Re: which is the fastest?
Post by aimeos » 20 Oct 2020, 16:55
Laravel is the fastest and easiest to customize so we would recommend Laravel.
Here's a performance comparison:
https://aimeos.org/tips/gigacommerce-ai ... ion-items/
Symfony 5 is slower than Symfony 4 (which was benchmarked) but Laravel performance stays the same in all newer Laravel version.
gebo
Post by gebo » 20 Oct 2020, 20:12
thanks a lot.
I was need this explanation.
But you suggest any hosting for it?
Post by aimeos » 21 Oct 2020, 06:11
The fastest we know in Europe is Profihost: https://www.profihost.com/
